H - Brace
blue thunder
ct.
My mechanic isn't sure what its for and where to install it. I have received it but unsure where to put it. Sounds stupid but let me know where to install it.
Thanks!!
Ishodu
Where the rear control arms connect to the body. Installs inside the box there.
SASHO91
Zoom Zoom
San Antonio,TX
In the middle of the rear suspension... were the control arms meet in the middle....
im not sure if you have o unbolt the bolts there, then bolt it to the studs....
i fabbed mine... and bolted it over the bolts there allready....
maybe someone else can chime in
freqsho91
virginia
I took the control arm nuts off pushed the bolts back to clear the h-braces new home, slapped the h-brace in place, slid the bolts through, replaced the nuts, and you're done.
olympic
Saskatchewan, Canada
Here's mine with tubular control arms:
Shoaz
Studly dood
Scottsdale, AZ
freqsho91 said:
Are the tubular control arms still available? :shrug:
You can get similar adjustable units from BMR or any GM supply place. W-Body control arms, four of the front ones.
