GTP tubular control arms
philw349
PhilW
Tucson, AZ
Just a quick question, I've been looking into those arms because I need to adjust camber in the back. How do they affect ride harshness. With Koni's on the light setting I think the ride is perfect. I've heard these stiffen up the rear but I'm not sure what that means exactly. When the car goes over bumps will you feel it less or more? And how much would they improve handling?
DeaconBlue
Cleveland, Ohio
The stock rear trailing arms with the ecentric TWR or Moog hard plastic bushings are worst that the GM tubular trailing arms, which have rubber bushings at both end.
PROPHET
Well-Known Member
Tonytown, Texas.
I just purchased the gtp arms from e.bay ,h-brace next ,installation. Tyler you out there ...help
FAST4DR
DeaconBlue:
Put down the Beer, NOW! :D
blackhawk60
Cary, IL
twrsho and deacon, can you guys explain the control valve arm a little more? I don't fully understand what the final modification for it was after installing the adj rods. Thanks
PROPHET
Well-Known Member
Tonytown, Texas.
The GTPs with all hardware to install from E.bay for $250 and H-brace $49 from Nooks .Installation $80 with weld for brake bracket.Very niceeeeeeeeeeee.
scott c
central florida
PROPHET:
Have an E-bay link or other info??????? Who did the install?? What about the brake issues??
PROPHET
Well-Known Member
Tonytown, Texas.
I dont remember the name ,the guy had a buy now for $250 it just had popped up ,with 9 days left.So i chose the buy now.I think his buy now went up to $330 .My local mechanic installed it.
tomw
Rochester, N.Y.
When I bought my arms a couple of years ago, I bought GM 10296341. I checked last week and was told that the number has been superceded by GM 10329694.
Tom W
Red 93 ATX
Black 92 MYX
viperrt450
Downers Grove, IL
ok back to this topic agian i was going to order the arms today and they said 10262699 was no longer avilable or whatever it is and they gave me this # instead 10329687 but in another post it said 10329694. They are both the same price. Which one is it anyone know?
<small>[ December 09, 2002, 04:58 PM: Message edited by: viperrt450 ]</small>
