Grounds/Intake
91 Plus
Well-Known Member
Monroe,Michigan
How many grounds are there on the intake manifold?
Also here is the way I got the vacuum ran!It was not pinched at all under the intake,and I didnt hear or see any leaks!
Also is this open or closed?
Rear
Front
I also found this plug and I do not know what its for?It is right below the oil sending unit,any thoughts?
<small>[ February 27, 2004, 06:03 PM: Message edited by: 91 Plus ]</small>
autobahnsho
SHO Victim
NY for now, WY for real
It looks to me like only 1 ground, on the back passenger support bolt (when looking at the car from the front.)
It's a 15mm nut on a stud that screws out w/ a 19mm wrench.
On the secondaries on a 1991- if you manually open the throttle (push where the cable connects) you can actually watch them open and close. And it's fun to hear the engine revving up close. :D
Maybe your green circle is a low oil light sensor??
