Ground Problem ?
Scott 99 SHO
Haverhill, Mass
Hi,
I just took my GEN 3 out of winter storage. I put the battery back in the vehicle and it started right up. My problem is when I shut the vehicle off the fan motor and oil light stays on. I checked the battery cables to the battery and they are clean. Does this sound like a ground problem and if so where should I start?
Thank you guys in advance
Scott :thankyou:
Could be a stuck ignition switch too.
The oil light will come on if there is power to the instrument cluster and there is no pressure.
slowshow
Tennessee
I have similar issues. When the car is on, my high beam indicator and parking brake indicator light stays on slightly. Not on fully lit, but not off, I gues sosmehwere in between. I was doing some audio work and thought I had messed something up or unpluged something, but not really sure if it was on before or not, as I have not driven the car in a while. I put eveything back together and it's still there. If you engage the e brake, the lights indicator comes on brighter, like it's supposed to be, as does the high beam indicator when the light switch is turned to high beam...???
