grinding into reverse
MaDDaDDaM
Kent, Ohio
I'm hoping this is a common problem in the SHO, for I've heard it discussed before. I have to ease my shifter into reverse, and even then, I get a little bit of grinding. Anyways, is there anything particular that should be done? Thanks, Addam
yamahaSHO
E85 whore
Arkansas
EDIT: This page does not have what I was looking for ... but I'll leave it up anyway.
Go into forward gear first... I use 1st or 5th, then take put it in reverse. I hear using 2nd gear lines the reverse gear up...
<small>[ December 19, 2003, 12:36 AM: Message edited by: yamahaSHO ]</small>
Dr. Tweak
Mad Scientist
Northern Vermont
yeah bro, just go into third, then reverse. Reverse has no synchro, that's why it grinds. Just go third-reverse, you'll be all set. I started doing that... no more grinding.
laugh_ti I love this guy! Thank you whoever added it!
*edit* lol you beat me to it. I thought it was third that lined it up though?
HEY! WHAT HAPPENED TO MY "HUH?" GRAEMLIN?!?!?!?! rant
<small>[ December 19, 2003, 12:18 AM: Message edited by: JDLangevin ]</small>
SHOTerror
Orange County, CA
As long as your not moving if you go into second first you won't grind reverse. Its gear is unsynchronis which makes for a real PIA.
Hack
Washington State
That's kinda funny lol I have always used fourth gear. I guess that pretty well covers the spectrum. pcorn
Blue-By-U
CT
Yup, just like everyone else said put your car in 2nd before reverse and it will never grind again. Make sure your car doesn't roll between the 2nd gear and reverse shift or else it will still grind.
DHMag
Free At Last
InCahoots, Texas
long before synchronized transmissions/transaxles came along, it was dealer recommended to first shift into 2nd before ANY gear. this would properly align all the gears for smooth shifting. i picked it up from my dad, and to this day, i still shift from second to reverse.
