Going crazy here! Please help.
Bizzy
Probably not in the right place, but I couldn't post to the general questions forum. Having a problem with my brake system...again.
Bad caliper brackets + non-moving slider pins = big problem. Got all new calipers, rotors, pads, brackets. Couldn't get one bracket off due to the bolts were heated on. Tried liquid wrench and a torch, no budging them. I'll have a shop loosen them and then snug them down and bring her home to complete the job.
Got one side installed (I'm not a stranger to my brake system) go to bleed the system and no fluid comes out the bleeder valve. Fluid is in the caliper because when I took it off fluid came out of it. Everything feels fine, but I don't like the idea of driving without all four brakes working as they should.
Anybody with helpful suggestions? Please give a poor SHO girl and hand before I go out of my mind. I've been driving a 4 banger since last Wednesday and I'm going nuts. Please help or put me out of my misery!
Proud to be an American!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
kmetros
Drug Pusher
South Bend, IN
Originally posted by Bizzy:
Got one side installed (I'm not a stranger to my brake system) go to bleed the system and no fluid comes out the bleeder valve.Anybody with helpful suggestions?
Beth,
Try jacking up the strut and brake assembly with a second jack before bleeding it. Having the brake caliper and wheel at normal riding height will allow the rear proportioning valve to operate normally and let fluid flow through the bleeder screw.
Give it a try and let us know what happens.
Kurt www.kurtmetros.com
Bizzy
Thanks Kurt...will try tomorrow...I'm done for the night.
Beth
Colgan Custom Bra
Mods in the works
E
EX-SHO_man93
Guest
possible collapsed hose?
Ryan
View5
98.5 SVT Tour
Mods: KN, Pro-M 75mm MAF, Tweaked Airbox, B&M, Mintex A/F Pads, KVR Slotted Rotors, Ford Blue Calipers (5hp per), Removed Door Dings, Sidemarkers, BN Motorsports HVAC Gauges
Ppsho2
EX 93 ATX SHO
Mods: KN, 73mm MAF, UDPs, Magnecore Wires, SHO Shop LPM & Y-Pipe, Dynomax Exhaust, Tokico Struts, Eibach Springs, Subframe Connectors, Doug Lewis 96 Brake Upgrade, Black Powder Coated Slicers, Police Interceptor Badge
RickieFrat
La Cosa Nostra
State of Corruption - RI
HUH ????
Randy ..... He was on my puter all afternoon while i was getting things done here. Hmmm, did I miss something ?????
Sry Bizzy ..... wish I could help you out in this. But when it comes to brakes i'm lost.
1992 TAURUS SHO **FOR-SALE**
Red/Grey Int
20% Tint
PIAA HeadLights
Boxless
1200 Watt System .... 131. DBs
Sig Pic By SHOTIME (THX)
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
www.fratsperformance.com
nothingtoseehere
Eric originally posted as "sell the SHO and but a Turbo Coupe" sorry he edited it so now it makes no sense
-RANDY-
Bizzy
Originally posted by kmetros:
[BHaving the brake caliper and wheel at normal riding height will allow the rear proportioning valve to operate normally and let fluid flow through the bleeder screw.
[/B]
***UPDATE***
Here's the update...All new calipers, rotors, pads and brackets on both rear wheels. Had troubles getting the (believe it or not) driver's rear rotor off. Took it in, had them remove the darn thing and bleed the system. I'd have never gotten that rotor off. Anyhow, he says that I have a bad proportioning valve on the right side and he had to break free the one on the left. So, I have 3 brakes working at the present time. New brackets and good slider pins make a tremendous difference in gas mileage!
Anybody have a proportioning valve laying around?
Beth
Colgan Custom Bra
Mods in the works
