Any oil that finds itself in the clutch and pressure plate area gets spun off by centrifugal force if it approaches the clutch from the perimeter.
An unlikely exception would be if the oil dripped down from the exact top location (lets say from a valve cover leak, or a rear main leak that get spun up the back of the flywheel, sits on the bell housing, then drips back down) and managed to sit on top of the clutch disc while the car is stopped and the motor is stopped. You would then have to have a habit of holding your clutch pedal down a long time before you got around to starting the car. Like you jump in the car, hold the clutch to the floor to get that start-thing activated, fiddle around to find your keys, then put on your seat-belt, and then take a few tries to start the car...... doesn't sound that likely.
But for that to happen, your entire bell housing area would have to be swimming in oil and you could get that info from removing your starter and taking a peek with a mirror.
The only other thing could be..... if tranny oil is being forced out the front of the tranny to the spline area where your pressure plate is splined to the input shaft. Then centrifugal force is working against you, instead of for you, and the tranny oil could migrate up onto the disc..... but that sounds like a long shot too. You would be at risk if you parked nose down, say in a below grade parking spot ramp, had a massive front tranny seal problem and your tranny was overfull (if that is even possible).
If you see yourself in any of these quirky situations, then maybe, but it would still be a longshot.
