I know that i have slowly leaked grease from axle cv boot closest to trans....well yesterday suddenly i heard groaning and grinding noise from front driver side wheel area. Jacked the car up and the wheel is move-able side to side and top to bottom..yikes. Took the wheel off and temporarily injected more grease into boot. I can pull the axle end (the part with bolt coming through the rotor) back and forth about a quarter inch.
This seems like a bad wheel bearing right? and probably should go ahead and replace the axle. Replacing the boot is a pain!
I have recently replaced tie rod ends control arm and couple other front suspension parts but didnt notice this problem then...it seemed to happen all at once.
