Getting the 3rd cat out
Izzmo
SHO Enthusiast
Kansas City, KS
So, I got my exhaust from 2,4shofast put in yesterday.
Sounds amazing.. but the damn shop wouldn't install the cutout since it's "illegal".
So, I tried taking off the 3rd cat and the flex pipe... wow is that shit on there TIGHT.
How would someone go about getting that off? I tried hitting it with a hammer and prying it off.. but nothing worked.. it's in the TIGHT.
~Nick
Assuming the ****** bolts are out a sawzall works on the back end.
Izzmo
SHO Enthusiast
Kansas City, KS
I think that's what it's came down to.. unfortunately.
The guy who installed it said he used heat to get it in there.. but I only got a propane torch.. I would probably get sitting there for a while lol.
E1 v2
crash tested
holiday inn
Do you have a cutoff wheel? even a Dremel cutting wheel will work.
If so, put 2 slices in the sides of the outer pipe running front to back, one on each side. Spread the slices apart.
Comes right off.
Silvapain
Limestone, IL
I did a modified version of Eric's suggestion - I hacked the cat pipe off at the joint to the catback, then used a sawzall to cut a slit in the inner pipe still left in the catback. Folded the inner pipeback on itself, and pulled it right out.
Izzmo
SHO Enthusiast
Kansas City, KS
Cool, well I'm gonna go out and by some bimetal blade for the sawzall and see what happens.
Thanks for all the suggestions guys.
BTW- GenIII running straight headers rock... amazing sound. Just don't get pulled over by a cop like I did yesterday!
ThatShoGuy
michigan
i know how this sounds, do you atleast have the Y piping on?
if not that is really loud if you just unhooked the Y pipe at the 3rd cat that thats what i did... thats no so bad besides the car rumbles under its self...
NebraskaSHO
Harumph!
Omaha
Just don't pull any cold air into your exhaust ports.
Izzmo
SHO Enthusiast
Kansas City, KS
Uhh.. I don't know if cold air got into them or not?
But I did get it off.. what a bitch that was.. I figured out it was all because of the person who put it on too.. ugh.
It sounds good though, so I don't think cold air got to them :p
Thanks for all your help, once again.
2 4shofast
Ogden Utah
Glad to hear that you got it all in, cant wait to hear some sound clips. Its nice to know it went to a good home
poffffd
