Gen III Steering Wheel on Gen I ???
SHO Mojo
West Chester, OH, USA
Guru's/Guru-ette's,
I've heard that a Gen II steering wheel will fit a Gen I, BUT...
...will a Gen III steering wheel fit a Gen I ???
Anybody know?
Thanks,
SHO Mojo
Thanks, SHO_DRVR,
Bummer. I was hoping that I might use one to spice up my interior (and replace the worn leather on my rim).
frown
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Well is it just a wire connection that is different because that is the only difference between a Gen1 and Gen2. To do a swap between the 2 just requires a wire splice and you are fine. Are the airbags still the same would be the question I would guess. They do look the same in most respects.
TheNoachSHO
Windsor Locks, CT
He was also asking about the Gen 3 which if I remember correctly are more then likely dual stage airbags. Which means seat sensors and other electronics.
I could be wrong.....
Gen 1 and gen 2 are swappable though
LOUDSHO92
Sponsoring Vendor
They do look the same but the difference could be in the airbags. If the Gen3 are a 2 stage then would it mean that they wouldnt work? Any one know if the Gen3 air bags are the same as a Gen2?
dan.delargy
