Storm-Chaser
Modified = cut to match the length of the OEM rear lower control arms. If you have a slightly shorter measurement due to lowering, I could cut them shorter to match your lowered-length.
You won't get any bent arms. If you look at that image, the two sets with the bent arms have shorter turnbuckles. These are a slightly different GTP adjustable arm and were the only two sets I had found. Those slightly different GTP arms are referenced here in past threads, and I did not read anything about them not working. So right now I am getting ANY of the slightly different arms, until I get enough "pieces" to piece-together a set and try-out.
I do take partials (ie. GTP arms with only a bent inner or outer arm), and use the partials to make complete arms, since they have to be disassembled for shortening. When I took that initial photo, I was in the process of breaking down several sets for shortening.
Interested in a set of adjustable control arms. By modified I'm assuming you mean cut shorter for a lowered car? Also, from the pictures, it looks like a couple of the arms are pretty bent up. Can I get a set of four unbent arms? Tried sending a pm but your box is full. Thanks!
