Gen I and II door glass adjustment how to!
oneqwicksho
cleveland, ohio
There have been a lot of postes asking on how to do this so I figured I would post this up for everyone to have
Step 1: Remove door trim panel and watershield.
Step 2: Lower door glass approximately 3 inches.
Step 3: Loosen nut washer assemblies (A) and (B) retaining the equalizer bracket to door inner panel
Step 4: Loosen nut and washer assembly (C) retaining door glass stabilizer
IMG00083 20110602 1941
Step 5: With door open, place hands on each side of glass and pull glass fully into door glass run assembly at B-pillar
Step 6: Tighten nut and washer (A). Apply downward pressure on equalizer bracket and tighten nut and washer (B) to 5-8 lb-ft
Step 7: Set door glass stabilizer so that it is slightly touching glass and tighten nut and washer assembly to 5-8 lb-ft. If the "B" hole is a vertical slotted hole, Make sure that the nut and washer (B) is positioned at the bottom of the slot as you apply a downward pressure on the equalizer bracket. Then tighten nut and washer (B) to 5-8 lb-ft.
Step 8: cycle door glass for proper operation
Step 8: reassemble and enjoy
Ps will have pic soon
tompumped
VT
Thank you for posting the info. I made it better with the info you gave me before, hopefully this will eliminate it.
Lcasho92
