Has anyone attempted to write down all that is involved in the conversion?
I would like for those that have tackled it to post up! List materials, parts needed, specs, tips, etc...
No, I haven't written mine up, but there's lots of info out there in a scattering of posts.
My take:
a) A post 5/98 SLO subframe is the way to start, the rear mount tower can be used mostly as-is. Considerable surgery is required on the subframe to make the MTX V6 powertrain fit - I think I've posted pix of my mods. I've got my car together with reinforced SHO engine mounts, though I'm now contemplating a set of Volvo S80 hydraulic mounts if I can figure out how to add a torque-control dogbone up top...
b) The Gen 3 SHO steering rack is a ZF Servotronic item, infinitely higher-grade item than those on other SHOs or Tauruses though its ratio is a bit slower than the Gen 1 rack. I'm the only one thus far who's bothered to wire up the Servotronic variable-assist, though at the moment I've got it unplugged. If you buy a used rack you will probably want new inner and outer tie-rod ends. Make sure to get the rack heatshield/pressure line support.
c) Power steering plumbing requires some work, you will need to adapt the Gen 1/2 pump hard-line end to the Gen 3 rack (you'll find other posts on this) and you will need to reshape the Gen 3 return line and adjust its routing to the cooler along the inside of the left subframe rail.
d) I think I'm also the only one who's used the Gen 3 steering intermediate shaft and the Gen 3 upper and lower rack-to-firewall boots. If you search my posts you'll find the pics of this arrangement; the Gen 3 shaft 'phases' better. This requires some trimming to the firewall, which I think is needed anyway.
e) The front crossmember of the Gen 3 subframe is shaped and located differently than the earlier subframe; things that bolt to the crossmember like the cruise-control servo and the power steering cooler will have to be adapted. Personally, I think the PS cooler belongs up in front of the car. I used the cooler set I'd had in my black car, since I've also got a trans cooler and pump in the car, though I'd made a nice little prototype bracket for relocating the stock PS cooler to the front of the car (another option in MTX cars is to use a Gen 2 ATX trans cooler for the power steering.) I haven't yet reinstalled the cruise control servo (I use cruise control about twice a year anyway.)
