vortex2450
Buying Parts...
I recently did a gen 3 brake upgrade. The bearings in the 94/95 knuckles I used were in much better shape than the originals on my car so I didn't replace them hoping I could get away with it. Well I didn't, the right side bearing is showing a considerable amount of play and the left side can't be far behind it.
So I am looking for advice on how to PROPERLY remove the old bearings and install the new bearings. I purchased two Timken (made in USA) 91-95 bearings with the hub assembly (part # 520100) so I won't be doing this again.
I realize these are press fit and I have access to a shop press. My questions are:
Do I press the old assembly out from the back(axle side) of the knuckle?
Do I press the bearing in first, install the cir clip and then the press hub into the bearing?
I realize the race needs to be spotless but do I need any sort of lub/anti seize liquids for the install?
Replies are greatly appreciated.
-josh
-josh
We'll definitely catch up and chat one of these days, so I'll keep in touch with you via *** on here.
