Gauging interest on Custom Kirkey Brackets
Jordan_R
Missouri
Gauging interest in custom Kirkey seat brackets. We can't use universal ones due to our offset and wonky bolt positions. Would you be interested in purchasing the brackets for ~$250? This is a completely custom piece for our offset bolt holes and weird mounting position. Would be not painted. Price isn't set in stone but would need to see what I could get done when I talk to the fabricator today and would rather aim high and come forth with a cheaper price over the opposite. Saves ~40lbs over the OEM seat.
What it entails:
Steel base brackets water jet cut with two 90 degree bends for rigidity with multiple forward and backwards mounting positions.
Aluminum side brackets with 90 degree bend on each side also has swivel mounting positions so you can gangster lean or straight back however your see fit.
Reuses OEM seat belt buckle with a bracket.
Grade 8 mounting hardware for the mount itself (reuses stock seat bolts)
This does not include the kirkey itself and is made for a 17" seat, however can fit wider seats just is untested.
CAQTXLb
TcUTL1O
ZnDYc9a
UKRokXC
mrhighcaliber
I'm interested. But mod funds are on hold cause I'm in the middle of an engine build. I have seats already picked out. Lol is that 250 for 1 seat brkt or both?
skyshadow07
Oklahoma
I'm made my own ugly ones. Thinking about re-fabbing in Aluminum though
