Gas tank door clips available at rockauto!
hawkeye18
Sorta cares
Norfolk, VA
I have a "new parts" RSS on my google homepage, and among other things (door lock solenoid being one of them), I noticed they now have the little springy things that always break on the gas tank door. At least, they have it for a 95 ATX. They're like 2.67 and some change. So, no more hunting through junkyards for them!
SuperHO
Mental Patient
St. Joe, MI
Are you talking about the lil springy thing that causes the door to pop open when you pull the lil lever?
Storm-Chaser
Shit Louis
Buy the Ford OEM part - Fuel Filler Door Spring Assembly.
The one I placed on one of my Taurus's has lasted for years.
The cheaper Dorman one I put on my SHO began rusting almost immediately, and then broke within three months - after having rust-stained the white paint where it attached to the Fuel Filler Access Door. :madflame:
You can distinguish the two, as the Ford OEM part has a straight steel-spring, and the Dorman a curved-spring.
SHOtimer - Doug, what dealer did you get the OEM part at? Dealer List is $12.47, and the cheapest I've found it, is more than $9.00 ! If you still have the receipt, could you post the Ford part number?
Thanks!
Yes. I just bought one from Ford about a month ago, only around $5.00.
Doug
SuperHO
Mental Patient
St. Joe, MI
man, it'd be nice to be able to get gas without having to open the trunk and pry with the corner of my debit card....
