Gas smell inside car
Kevin
Winsted,CT
I get a gas smell at a stop light when the car has warmed up. I've read the SHO FAQ regarding the gas-fume purge valve and canister but can't find them in my 1991. Does the 91 have them and if so what does the canister look like ? Do I have to remove the air box to see it? Are there any other causes of this condition ?
It is located under the ABS package near the air box on frame rail.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
Blast7
Rochester, NY
Also check the purge solenoid which deals with the gas fumes. It is around $70 from Ford and it fixed my gas smell problem.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
~1st Gen Black rust free trunklid
~1st Gen Black rust free front door mouldings
