fuses
tysonfrk101
Wisconsin
fuses keep blowing in my fuse box. Specifically the fuses for the blinker directionals. The a/c is also not working but i dont know if it is fuse related. any thoughts? shoot me a pm
firebat45
Edmonton
I'm going to venture a guess and say you have a short somewhere, probably in the blinker circuit.
A/C not working might be the clutch, try to listen for it clicking when you turn AC on and off, or your lines could be empty. There's other causes too but those are a good start.
tysonfrk101
Wisconsin
i can't even turn the a/c on. another thing i noticed is that the digital clock is blank. I dont know if that has anything to do with the problem or not.
TYSHO
Earth
Take it to a small shop and have them vacumm check the a/c to see if it will even hold a charge, then check how much of a charge you have in there if it holds. Once you go under 25psi or so, you're compressor wont even kick on. Freon is cheap on a/c unit. If you have the old r12 set up, keep it and have the shop refill with Freeze12. I know a guy who owns a shop that checked my vacumm and put a bottle of Freeze12 in for $15. You wont get lucky like me, but the price will not be far off.
