Full Size Spare Options (20") Needed
J persons
Natchitoches, LA
"Close Enough" is not good enough for me. I want a spare with a near identical circumference as the four wheels on the car.
I use a cop car 18" wheel fitted with a 245/55-18 Kumho tire. It's as close to the original circumference as I could get. It has never been on the ground, so I can't give any recommendations as to how it compares to the Michelin's that I use. The fit in the tire well is tight and it can be a bear to pull out sometimes.
Peetah75
Pomano Beach, FL
I'm afraid to go on a long trip without a conventional spare. What are the options?
Small floor jack suggestions would also be welcome.
TIA.
I have a 2013 with pp and 20" recently paid $300 for a tow after I tore a tire on a curb. I could not find a 20 in steelie so I bought a used 20" alum rim on ebay ($165), mounted an old tire on it and it fits perfectly in the well of the trunk. Bought a scissors jack on amazon and a lug wrench at an auto parts store, so I'm all set, just like the old days. Good luck!
Mr.Atomic
I was commuting around 150 miles a day and occasionally use the car for road trips and had the same concerns about not having a spare. (2013pp with 20" wheels.) I once had a puncture in the sidewall and was just able to make it to a tire store using the factory kit with slime and compressor. I said never again. I had to replace the tire from the sidewall puncture, so I ended up buying a new set. I kept the best one and had it mounted on a factory rim I bought on ebay. I just keep it in the trunk with a cheap jack so if I ever have a flat, I can swap out the tire and keep going like nothing happened. I don't have to worry about tire diameters and widths, and I can get the flat fixed at my convenience.
shootinirons
