cd57078
I miss my SHO
Does anyone know how to remove the fuel rails. SDPATT kinda told me something about how they pivot off of the passenger side, but me and my dad are still confused. If anyone would care to chime in, that'd be great.
I am employed as a software engineer for a defense contractor helping our boys kick Iraqi butts. I make more doing that than as a nuclear engineer working for an electrical utility at a nuclear power plant. And I don't have to wear anti-contamination clothing and have full body dosimetry scans on a regular basis.JoeHoe_SHO:
Yeah...Scott is the man...Check out his car sometime...very nice. I hope my car is that nice someday...I wish I was a nuclear engineer that makes gozillions...![]()
Just an FYI to all, mixing a hot utility light and fuel systems is a big no-no. There is always the potential of dropping the light and breaking the bulb. The bulb is more than hot enough to ignite any fuel that may be in the wrong place. Happy wrenching, but keep it safe.sdpatt:
To remove the fuel rails, you first must remove the intake manifold. You then must unclip and remove the six electrical connectors to the injectors. Remove the bracket at the driver side that supports the connecting tubing, then the four bolts that secure the rails to the heads. You can then wiggle the rails up as you pull the injectors from the heads. You do not want to have the injectors separate from the fuel rails. Pivot the rails up at the passenger side as shown in the photo below.
