fuel pump
mccrash
ga
hi everyone,my trouble is the the guy that had my 94 sho manual.has bypassed the fuel pump cut off switch and run it to the fuse box under the dash,i dont know were the switch it or if its steel there,any idea what i need to do,to fix it.
dstig1
Hudson, WI
If you are referring to the fuel cutoff that trips after an impact, it is in the trunk. Drivers side wall, there is an opening in the trunk liner and a red button back behind there.
Not really sure if that is what you are looking for or what the problem is...
