Fuel pump?
quake
rochelle il
Car stalled out while warming up.Came out to restart and fuel pump was still running.Any idea why,thought it built pressre and shut of.Hi flow pump,and 48#injectors
Irish Pride
Irish Inside
MusicCityUSA
Did it restart? Cars stall out for different reasons all the time.
quake
rochelle il
reply
no gas in tank.car cut off with key on and fuel pump never shut off keep dumpn gas into the engine while engine was off.
General Geoff
Pennsylvania
I would think the return line would, you know, return the gasoline to the tank from the fuel rails when it was not being consumed by the engine...
deercrusher
never running!
PA
Your ccrm may be faulty. Allowing voltage to go to the fuel pump when the car is off. And i doubt any gas went into the actual cylinders while it was doing that because the injectors would have to be opening.
quake
rochelle il
Yes
Gas went into the engine.It was like it was flooded out.Start up,but ran like sh??t.I could see the gas blowing rite out the rear pipes.So i let it sit for like two hrs.Start ran fine,not the flooded out gas and smoke everywhere.3.2 wit a sct chip.
