Fuel pump testing?
naval-avi8or
Chesapeake, VA
If you buy a comprable relay and wire it in than it will have the PCM controls just as the CCRM does. However you'll spend more time as wiring it in then just waiting for your new CCRM.
doclees
Harrisburg pa
Follow up folks. Just put it my Autozone "fan relay module" as they call it. Had some issues getting it to reset everything but it is running but the saga continues with factory alarm issues now. I will start another post. If you like puzzlers this should make your day.
Gen3
DFW, Texas
so...umm... Am I the only one who doesn't know what a "CCRM" is? (I'm suspicious of Fuel pump problems too)
doclees
Harrisburg pa
It is a multi relay box under the plastic cover of the radiator. Autozone calls it a radiator fan relay module.
poffffd
