SHOtimer
#2910
Got up early this morning to tackle my fuel pump and then replace my rear calipers. As of now calipers arn't done and the SHO won't be running untill Tuesday night. I pulled the SHO in the garage, with the gas light on (so the tank would be nice and light). Using my arm and a few jacks with wood on top I managed to bring the tank down easily and uneventfully. I now procede to unhook the pump, that went fine. Now, their is this other thing behind the pump that has two tubes coming out of it. I figure it is some type of a fume vent (which it is). I get my hand over there to pull it out and snap, breaks right off in my hand. Great! headbang So, at this point I know I'm not getting to the brakes and she isn't gonna be leaving the garage today. I remove the tank swap the pump and call my stealership and the part will be in Tues. Some type of a vapor valve of sorts.
So, moral of the story: Be very careful with the vapor valve when disconnecting it to do a pump swap. I'm not too worried about waiting till Tuesday I was just excited that it wasn't discontinued. Driving my car and working on it is most of the time living and driving in fear that something will break that will be a PITA to locate if it still exsists....
Doug
Doug
