fuel pump relay!!!!!!!
shoftw
where is the fuel pump relay at on a second gen and is it the same as a first gen? :thankyou:
jonheese
Used-To-Know-It-All
Fogelsville, PA
The box is in the same location in both Gen1 and Gen2, but the boxes used have subtly different innards.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Is that strictly true?
Unless I've been misinformed, I believe that a Gen1 SHO CCRM will work in a '92 or '93 MTX (and vice versa), as they both use J CCRMs.
No?
No they will not swap. Only ATX use the J Code only.
jonheese
Used-To-Know-It-All
Fogelsville, PA
Sorry, brain fart. Let me try that again:
Unless I've been misinformed, I believe that a Gen1 SHO CCRM will work in a '92 or '93 MTX (and vice versa), as they both use M CCRMs.
No?
LOUDSHO92
Sponsoring Vendor
No?
As you said earlier its based on the code. So an M code will work where an M code has worked. A D code will not work where an M code worked.
shoftw
thanks man that helps out alot cause i am aquireing a new sho and it is a 92 that works out awesome :thankyou:
jonheese
Used-To-Know-It-All
Fogelsville, PA
Okay, just making sure. You said:
LOUDSHO92 said:
No they are different for the Gen1, 2 and ATX versus MTX.
and
LOUDSHO92 said:
shoftw said:
so u cant use it on a gen 2?
So I was just making it clear that that's not strictly true. It's all about the letter code, as I posted earlier in this thread.
Piece of cake if you have some knowledge. Worst that can happen is you burn the car to the ground......
4SHOx
