shobikes
...the stupid tank o-ring ain't sealing!
In a nutshell: installed my Walbro 190 today. I had no help, but at least only 2 gallons left in the tank. I got the tank down, but it slid off the jack and broke the outlet quick-disconnect right off its hose eek! . So I finished pulling the tank from under the car and noticed I have had significant fuel leak at the tank sealing ring for who knows how long - the plastic 4-wire connector crumbled to rubbery dust when I touched it eek! eek! . SO I pulled the tank unit out, installed the new pump, and noticed the in-tank red rubber return line end fitting was torn (what does that thing do??!?).
Dammit! I said. The parts car was tucked waaay into a corner where I couldn't jack it up or drop its tank, so I started cutting an access panel beneath the rear seat. I only had one cutoff wheel, and burned it up before completing the cuts, so I drilled a couple hundred 1/8" holes to perforate it sufficiently to gain access. I managed to get the tank unit out of that car, and salvaged the outlet line as well (Short one, that goes right into the filter), and got the wires out of the 4-pin connector shell so I could use it on my car.
Anyhoo, it all went back together well, and I don't think I broke anything else. The tank unit seated on the o-ring, and the locking ring seated fully under all the tabs. I was very cautious to keep the tank on the jack and not connect anything until the tank was wedged above the exhaust pipe. Car starts, so I drive it to the gas station and fill 'er up...
When I got home, I parked nose-down on an incline, and damn if the stupid thing's not just DRIPPING steady on the driveway.
Now I have a full tank of gas and a new pump, but the stupid thing's leaking worse than ever! Any ideas? I don't really want to use RTV or any gasket stuff on an o-ring. Should I grease it? What have y'all done in this case?
