Fuel pump door
jayro
Auburn, In
I will be replacing my fuel pump in a few weeks (just waiting for it to arrive). I have all the measurment for cutting the access door under the back seat, my question is what is the best tool to cut the door? I know not to use a torch.....I was thinking a cutoff tool or maybe an air chisel. I just want to make sure that I am not going to set anything on fire since I still have some gas in the tank. Thanks
Jeremy
hawkeye18
Sorta cares
Norfolk, VA
dremel with many cutoff wheels. Whatever you do, don't go more than half an inch past the metal! Fuel lines + cut = BAD
