pin 19 on the computer does not supply power.
power comes out of CCRM pin 5, goes to splice S152, then splits and goes TO both the fuel pump and the computer on pin 19. 19 is FPM, fuel pump monitor circuit. if the computer doesn't see power going to the fuel pump it kills some of the engine functions.
power starts at key, key sends power to CCRM, relay on CCRM sends power to computer.
I once had my 92 die, it was the splice S142 yellow wire, that corroded and stopped power from reaching both the CCRM and the computer.
Perry
Since this is a 90, I think the numbers are a bit different. Splice 403 is the one that goes between pin 19 on the PCM and pin 5 of CCRM and back to fuel pump. So I assume the splice 142 you speak of is splice 275 on this car (it's near C124 right on top of the cooling fan). I am getting KAM power to both CCRM pin 8 and PCM pin 1, so that means the splice is good, and the fuse-able link is good. There are some pretty unorthodox wiring repairs from the deer accident, but I am getting power through!
if so, you should confirm that the key switch is good and actually telling the pcm to "turn on" when the key is turned.
What wire tells the PCM to 'turn on?'
engine compartment fuse box, EEC relay, hot at all times feeds power to CCRM pin 8, and computer pin 1. thats the KA pwr,,keep alive power.
CCRM receives power in start or run on pin 13
from a 92 manual.
Perry
As I said above, I get power to CCRM pin 8 and PCM pin 1. Pin 13 has 1.5V on start. Is this right? I also have 5V to pin 24 on the CCRM when key is on. So from what I'm seeing, it appears wiring is good so far(well, at least the continuity is good, it looks like a rats nest of twisted together wires, electrical tape and wire nuts).
So. Now what? I supplied battery voltage to pin 13 to see if it wasn't getting enough power, but nothing happened. Where do I go from here? It seems like I can find flow charts for no start conditions, but it's only for the starter not working, or no spark.
I'm sorry for all of the questions, but it seems like I get some weird cases. The last 94ATX no start I had took me almost 6 months to solve (including buying a parts car to swap harnesses with).
I'm just looking to understand how the fuel pump is turned on. If I knew exactly what I need to the PCM and CCRM in both key on and start (and what pins, etc), that would be great!
Thanks so much for all the help so far!
