Fuel Problems
Gillette, Wyoming
I dont have any fuel pressure at my fuel rails. I just changed out my fuel pump and my fuel filter. I checked to see if my fuel safety shut off switch was tripped, it wasn't. I don't know where next to go. The car will crank but won't start. Is there a fuel pump relay on SHO's if so where and im not sure but I think the pump isnt even coming on when I turn the key.Thanks
SHOtimer
#2910
Santa Clarita, Ca
Constant Control Relay Module. It controls things like the fuel pump and the engine fan, AC..and the like. It is under the plastic piece right above your radiator, it has a capital letter stamped on top of it.
Doug
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
ShoMeWhatIWantToKnow:
Thanks maybe this will get my SHO running again. Does any one know the price for a new fuel pump relay?
Well, I'm not sure, but I know you have to buy the whole new Relay module, you can't buy the fuel pump separately. You might be able to find a used unit to save some money. Good Luck!
LaTechSHO
Louisiana
MTX CCRM is Four Seasons/Factory Air/Murray Part number: 37510
ATX CCRM is Four Seasons/Factory Air/Murray Part number: 37512
As for price.... last i checked it was around $100 for either.....
Louis
