bertha66
I have a 93 SHO, I put in a clutch in my SHO and then about 2 weeks later it stopped running. There was no fuel pressure at the fuel rail. The car started after 3 hours of sitting. It did this 3 times. I put in a new pump and filter and still not running. I checked the voltage at the pump-6.75volts at the top of the tank but when you plug in the pump voltage goes to 0 volts. I changed the mult relay under the hood with a used one and no change. I checked the ground under the hood, all are good. Anyone seen this before or any ideas? Need help, Thank you for any ideas.
