Fuel pressure gauge mounting
Bluto
Rochester, NY
Doese anyone have a fuel prussure gauge mounted inside the car?
If so was it hard to do, and how safe is it?
TheNoachSHO
Windsor Locks, CT
Unless you can find one with an electronic sender....not even sure if that exists, you have to ask yourself "is it a good idea to run a fuel line into my car". I know what my answer would be.
Bluto
Rochester, NY
I realize the risk involved, thats why I asked if any one has done it.
olympic
Saskatchewan, Canada
Fuel pressure gauges don't actually run fuel into the car. They either use a mechanical isolator or an electrical sender.
A mechanical isolator is basically a cylinder with a rubber diaphram in it. The fuel is pumped in on one end and there is a non-flammable liquid in the other end. The diaphram seperates the 2 and transmits the fuel pressure into the non-flammable liquid which then pressurizes the gauge for the reading.
An electrical gauge uses an electric sender which converts the fuel pressure into an electric signal that is read by the gauge.
The mechanical gauge is considered to be more accurate but the electrical gauge is cheaper and easier to install.
Dave Ladely
Seattle, WA
Check out the Greddy guage, its very accurate, electronic so the sender is remote from inside, and the backlighting matches the SHO! Really great quality!
olympic
"Liquid filled" is a different thing altogether and is generally only needed for dedicated race cars. So you'll just be asking about mechanical or electrical type gauges. I'd recommend an electric gauge because they're cheaper and easier to install.
jthomas68
Area 51
Swing by my house next week and i`ll show you one mounted on the hood.It also is getting polished fuel rails. :)
CTOESHO
DeKalb, IL, USA
olympic:
That liquid is a mixture of 50/50 antifreeze and water.
If you want something that is more accurate than our mechanical gauges, it's our new Stepper Motor full sweep electric gauges. We currently have 2 series that utilize these new motors, they are C2 and Cobalt.
