nomad327
I've been looking all over the net and getting some insight to my problem. I will sum up what I have seen, and discussed elsewhere. This is not an emergency, the car is home and I have a spare vehicle.
I have an 89 MTX, well maintained. We bought the car new and it is unmodified and has always been perfect. It got a new Cam sensor about 9,000 miles ago, and about three thousand miles ago it had a new timing belt water pump crank position sensor and all the cam and crank oil seals, all Genuine Ford parts. It's Now about 101,000 miles. My wife drove it about two miles the other day, and shut it off and it would not restart. The car was towed to my house. I checked it over the fuel pump runs and there is fuel pressure at the Schrader valve. The camshafts are turning and it cranks strongly and seems to have good compression. There is no spark at any cylinder using an inductive timing light to check for spark. I had an autozone test of the DIS module as it is the only part not replaced recently and it passed five times. The tachometer needle moves a bit during cranking, about a needle width and the check engine light is on in the run position and while cranking. I tried jumping the starter solenoid with the key in run to reduce the likelihood it was the ignition switch, and it spun well, but did not make a spark with the key in run. The ground cables and battery cables seem to be sound, and the related connectors all seem tight. There is no indication of water pump leakage. I did the KOEO test and the relays and pumps cycled and I appeared to get several 11’s in a row, and then two 67’s which appear to be unrelated. I also checked the MAF and cam sensor connectors and alternately tried starting it with each disconnected, no change. Has anybody seen anything like this? I have been told the CPS is probably the culprit, but it is just barely broken in and was installed properly. I will replace it again if that seems like the problem. Thanks in advance, Ed.
