Fuel Line issue
Brett87lx
Indy
My fuel pump died recently, and in the process of dropping the tank the line that runs to the fuel filter broke off. The dealer wants $130 for a fuel line kit. I just happen to have about 3 ft. of rubber fuel line and want to replace the old line with that. Would the rubber line be able to sustain the fuel pressure or is there a better alternative to buying that fuel line from the dealership?
Thanks
SHO_Driver
Montreal, QC
You should be able to repair that plastic line with a repair kit that can be spliced in. Check at almost any autoparts store. I used a rubber line over the plastic as a temporary fix, didn't leak but not ideal.
Mr Anonymous
Tire Wall
Thanks
Most rubber line says right on it "not for fuel injection systems" or something to that effect.
Try posting a WTB in the appropriate section, that might be the best bet for getting the factory part cheap.
djsSHO
Ford Nut
Buffalo, NY, USA
Yeah I'd post in WTB or even a local junkyard would probably have it. The rubber hose would probably work, but getting a new line would be better for the long run.
