olympic
Well, the SHOpaz finally rumbled to life today, but not without a little life support. What could cause the fuel injectors to not fire at all? I have the intake grounded in 2 places and I have 40 PSI fuel pressure while cranking. The engine will run if I spray a little gas in the intake but it just dies right away.
I completed all the wiring that I thought needed to be done and all the connectors, ECM, PCM, DIS are hooked up. The DIS worked fine when the engine was still in the parts car. I checked the front DIS plug and there was power coming to all 3 yellow wires but no power coming out the rear plug on any of the pins. Is there a way to test the DIS with a multi meter or something? Or could this problem be the ECM? Like I said, the engine runs fine as long as I'm pouring the gas in. I had it running for a couple minutes this way. All opinions welcome and thanks!
P.S- the SHO sounds pretty raunchy through a wide open catless y-pipe...LOL!
