fuel injector issue!!!! help
sbsho
Spokane, WA
i just installed my new 39# INJECTORS. car started up began to idle like it was not getting enough fuel. turned it off for like 5 to 10 min. then came back to turn on so i can bleed my right rear brake. wont even start, just cranks? i have new 225lph fuel pump to install. is my ecu going into safe mode or somethin. thanks for the help.
Is it flooded? Try holding the gas pedal down while you crank. If you don't change the PCM programming for larger injectors then too much fuel gets injected at start up as this comes from fixed tables.
sbsho
Spokane, WA
ok, after takin off the upper intake manifold and reasembling it it starts up. i just installed the larger fuel pump to see if this would help it out. it starts fine now but after like 3 minutes it starts to wobble in the idle from 1000rpm to 1300rpm. should i be worried about that or not because of the mods ive done to it?
1993MTXSHO
Its a Taurus...
Jersey
do you have cams and a lightweight flywheel or both, that can cause an irratic idle? Also do you have an adjustable FPR to use with the 255 pump, that can also cause problems if you don't?:)
sbsho
Spokane, WA
i dont have cams or flywheel, its most likely because i have the stock fpr. i just took her out for a spin and she ran fine up to bout 5000rpm, then it seemed like the stock fpr couldnt handle fuel after that.
AREA 91
PA SHO SHOP
Area 91
What mods do you have?
Unless you're boosted you don't need a 255lph pump.
Mr Anonymous
Tire Wall
Running a blower car without a tune? Keep running it and you'll never sell it unless someone wants a blown up one for $1000.
Until you can have the car properly tuned, just park it. You've advertised the car as an unfinished project, just leave it that way rather than screw it up. An FPR is in order.
93rev2sev
Hockeytown
Did you have to modify anything for those 39ers?
