FS: Supercharged 91 SHO $2500/3500
kevinspann
Don't take my advice.
Richmond VA
Vortech supercharged 1991 SHO for sale: $2500 as it sits, $3500 with the quaifed trans reinstalled.
Red with black interior, Plus hood. Paint is bad, interior is decent minus the seats, the fronts are split in the seat area, the top of the rear has dried from sitting in the sun. Has some rust in the dogleg on the passenger side. Some bubbling underneath the gas door. The bubbling area appears to have a skim coat of bondo on it, and that quarter and door were repainted.
Has:
-Vortech with 3.61" Pulley, about 6psi, SHOshop piping, SCT chip that was tuned by FPS some years ago, unsure of injectors, I did not pull them to check. It has an 80mm Lightning maf
- Stage 1 cams
- BBB in a hand ported intake
- 3.0 block, as far as I know never been rebuilt
- SHOshop 3pc UDP set
- A stock diameter aluminum crank pulley, anodized the same color as the vortech pulley.
- SHOshop catback with dynomax mufflers
- Not sure what brand of y-pipe was on it, the cats were replaced in it at one point. Has a plug in the front bank, presumably for a wideband.
- Tokico/Eibach
- ALSFB
- 94/95 Knuckles with 96 brakes
- Full length subframe connectors
- Rod shift car - could use some rebuilding to tighten it back up.
- Trunk mounted battery
Car is currently sitting on gen 3 chrome wheels, 17" OZ wheels and tires from my parts ad available on it for an additional $500 if purchased with the car.
The car runs and drives ok, I bought it with a toasted Spec clutch (that didn't have that many miles on per the receipts with the car). I replaced the clutch and flywheel with stock parts to get it mobile. I put a stock non-quaifed trans in, as my plan was to pull parts of the car and return it to stock to sell. The trans that went in was unknown, and shifts awful, hence the price, and the options to go with a reinstalled quaife trans.
The quaife was installed in this transmission by FPS back in late 05, based on all of the other receipts I would say that it has about 40k miles on it. The odometer currently reads 83xxx, certainly it has rolled over.
I decided that I don't really want to put the work into parting the car and returning it to stock, as it would be much easier to sell whole.
Here it is, on the OZ wheels. Car no longer has the cobra brakes.
And the Vortech. Idler has been relocated, and a new, longer belt is being used.
Vortech zps8c366785
vortex2450
Buying Parts...
North Carolina
I am astounded that noone is chiming in. I've riden in this car and it feels good even with the big pulley on it, I am sure with the quaife'd trans this would be a very fun SHO.
-Josh
kevinspann
Richmond VA
I took a few more, not a bunch like I said.
Pretty much the paint on the top side of the car
A terrible video of start up. Hadn't started it in a few days. Not sure if ****** tune or vacuum leak.
[youtube]RYi_rsG1qPI[/youtube]
The trans that is in the thing would need to be replaced with another, or fully disassembled and gone through to make sure everything is right.
TimboSHO
Intermediate
Wyoming, MI
Every time I absolutely don't need another car something like this comes up for sale. That's how I got the last 2. I'm sure it will be sold by the time I'm physically available to have another car (summer).
GLWTS!:naughty:
kevinspann
Richmond VA
GLWTS!:naughty:
If it doesn't sell in the next couple weeks, this thread will be moved the the SHO parts cars section.
kevinspann
Richmond VA
Probably. It seems to be okay out on the interstate - it around town driving that sucks, because of the trans. Other than that...it's a car. If I had a way to get back, I'd drive it there...
Edit: And could do so at the end of next week...
SHO_OFF
SHO Reviver
Loveland, CO
Does the stock clutch/ flywheel hold fine now, or would they need replaced also? Trying to figure if it would be worth picking this up soon for Fred (rubydist) and I to play with. Any idea on good but cheap shipping companies?
kevinspann
Richmond VA
Added: ABS light is on, haven't pulled the codes. Airbag light flashes a code 6? Could be the clock spring, not sure. It comes and goes.
Donut gasket is leaking, I'll try to replace it if the car doesn't sell - someone is coming to look at it Wednesday.
I think the MAF adapter is leaking, but it could be the coupler there. I had to leave it alone, I'll come back to it in the daylight. I could feel air there though.
SHO_OFF
SHO Reviver
Loveland, CO
Dangit and Congrats! Are they a forum member? If not did you tell them to stay away or they will get sucked in... Lol
bmytych
