Frankenmuth meet Feb 12th
98shotoy
R.I.T Team
Monroe, MI
RonPorter said:
If you only "touched" the brakes, and didn't use a BFH on any other suspension parts, you are on the right trail with the sliders.
Another thing to consider is how much you compressed the pistons. if you didn't do both sides the same (I always compress them ALL the way in), it could pull for a bit until they adjust.
The other factor is the brake flush. make sure both sides are done. You really should do the full system, as the two fronts are on different circuits.
I sound like a broken record, but getting a Motive pressure bleeder is the only way to get a flush done right.
Another possibility is that, if you didn't use new rotors, or get the rotors cleaned up (personally I always get the rotors cleaned at the local muffler shop with every pad change...if I'm not doing new rotors), you could be getting different contact patches side-to-side, which will eventually correct itself.
In any case, she should still be fine for the drive.
You know after reading your post I remember having problems getting the piston decompressed all the way on the side that its pulling too. I wonder If I did it too hard to where it needs a little help back out?
Those I shall check for along with redoing the lides again. When I drove it work the other day it did pull enough to where you could not take your hands off the steering wheel. At first I thought the tire was going flat. Like I said, I have done a million brake jobs and never had this problem.
todras
Grand Rapids, MI
Really guessing a caliper issue is the only thing that could do that. If the car is tracking/driving fine it has to be a brake/caliper issue.
RonPorter
SHO Club of America
Lake Orion, MI
That is a possibility. That piston bore may have some corrosion or crud in it, so it is either leaking a bit, or hanging up the piston.
If the obvious stuff that you check doesn't do it, getting a reman caliper for that side may do the trick. If the remans are pretty cheap, you mght just get one now and be done with it.
If that's the first brake job since new, and still has the original fluid it may have had some moisture in there that is causing the problem.
SHObill
'The Collector'
Rochester MI-48307Detroit
Todd, bring em! I'm planning to be there. We'll see what shakes out with family. Hopefully the weather hold out & we don't get any white stuff!
ALSO if anyone was thinkin bout pickin up a set of valve adjust tools I can bring em! They are even cheaper in person!
pjtoledo
'ol man in the SHO
toledo,ohio,usa
If its the brakes making it pull when just driving then at least one wheel should be getting real warm, real fast. After a mile or so, just get out and (carefully) check each rotor for heat. Be sure to do the rears too as a problem in the back can do strange things to the front.
Perry
RonPorter
SHO Club of America
Lake Orion, MI
Unless the problem is a piston sticking that doesn't work properly. It may not cause one side to drag, which is what will cause one rotor to get hotter than the other.
98shotoy
R.I.T Team
Monroe, MI
No I wont be there. I ended up having to go to work today. I had to go in because I had to do 8 cars which one was a 15 passenger van. So, needless to say I didnt make it to he wife's car today. I didnt even get off work till after 5pm and I was only "suppose" to work 3pm. It was a VERY busy day today. Man, even though the weather was crappy, alot of people wanted their vehicles detailed.
91 Plus
Well-Known Member
Monroe,Michigan
Damn I might not be able to make it now.
The kid that is suppose to work for me, his car broke down. I am trying to get someone else to come in.. Hope to see you guys later.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
AH, come on Ryan,,, we were counting on you to bring the pizza! :frown:
Perry
98shotoy
R.I.T Team
Monroe, MI
Is anyone back yet? I just got back in the house after working on the car all day. Nothing new to report on my end. The gosh darn thing STILL pulls and I took everything apart and relubed and greased....all that good stuff. So, I am going to take it to work with me and see if the alignment is out again. The shop i took the car to to get tires and an alignment wasnt a good place to take it....although I was told this after the third time I had to get the car aligned. Oh man I think this place messed the car up.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Of course it was good. Not a real big turn out, 12 people at Bronners, 10 at the Bavarian Inn Restaurant. 3 SHOs, my Ranger, Jims GTP, Ron Porter's Subaru, and a red Pontiac Solstice(I think). Oh man, I forgot his name,,my bad. Weather was great for driving, food was also great. Chris took pics, hope to see them posted soon.
Perry
