Ford Sync / Jukebox / MP3 / USB / CD / DVD
Charlie Blanko
2010 SHO Black On Black
Or try Master Reset in the SYNC settings menu first. Shodded is correct though the fuses are small and a tight fit. The cover should have a fuse puller but still be careful.
If pulling might I recommend a towel on the floor near the fuse panel preferably a light contrasting background so if it does fall fairly easy to see.
With the fuse puller, it's pretty easy. But, should I disconnect the battery cable before pulling the fuse? Also, the hard reset in the sync program doesn't seem to do anything, or I haven't done a "Hard" reset yet. Whatever reset I did... My channels didn't change and nothing happened from pulling the fuse either.
