Ford SCREWED me on the PTU
Fordnatic
Alaska
2010 SHO PP. Splurged and bought it new (wanted one nice new car before the kiddos came along). This car has had a pampered life that every car would aspire to. Only spent a couple nights outside the garage, just one track day when it was about a year old with a half dozen runs, meticulous care and maintenance. Its just shy of 80,000 miles and......Looks like the PTU is about done. Since the twins came along, I haven't had time to keep up on here or I could have seen it coming and maybe prevented it.
The wife and kids were on the highway last fall when they just about gagged from the smell, had to open the windows. When they got home I drove it and everything seemed fine, so I assumed it was a vehicle in front of them. Well...two months later (next time I drove it) it was whining. I did some research on this list and apparently the smell was the PTU giving up and boiling what was left of the sludge that used to be gear oil out the vent, onto the exhaust and getting sucked into the HVAC.
I needn't have bothered wrapping my drill in plastic when I drilled the PTU to tap a drain plug, as NOT A DROP of oil came out. I don't really have the 2 grand to get it fixed right now, so I'm gonna try to limp it along for a while. I had the car up on jack stands (all 4 wheels), so I ran it in drive and flushed it 5 times with ATF. At least it wasn't thick at the last. Filled it back up with 75W140 along with a little ATF and have about 200 miles on it so far. Not sure how much longer I'll get out of it.
Where is the recall??? No way a major drive train component should fail at 80000 miles on a pampered car.
jman1200
Ontario
Sorry to hear about that and you are not going to like what I am about to write but you have been a member of this forum since 2010 and didn't know that you could not rely on the PTU's "lifetime oil" ?
I read about that within a few weeks of joining and immediately starting replacing the oil at least once a year (20k km).
How does it sound after what you did?
Sorry to hear about your misfortune. However, how did Ford screw you? I could say the same thing about the 4.6 liter in my old Expedition....the timing chains ate through the guides, which ate through the tensioners, which caused the chains to skip which blew the motor.....
Even the dealers are now performing maintenance on this 'lifetime' unit. Sealed lubricated components are lifetime- as in- lifetime of the unit, not the vehicle. As long as they make it out of warranty I don't think they care.
Fordnatic
Alaska
As I specified in the post, after the twins came along Dad had no more time for perusing forums. They are 7 now, 7 years ago it wasn't a problem yet.
It has a slight whine at times, but I put on the studded tires while I had it jacked up and they are quite noisy, so it's hard to compare with before I drilled and serviced it.
Fordnatic
Alaska
Like I said, a major power train item failing in less than 80k = screwed. Sorry, but the engineer that thought of making it non serviceable and those that approved it should be relieved of their jewels, as we can't have that kind of idiotic incompetence in the gene pool.
xFallenxCripplex
I'm guessing the didn't test how hot it would get as synthetic oil has gotten really really good but sad and angering that once they found they fed up that they haven't changed their stance very quickly
Sent from my Pixel 4 XL using Tapatalk
It's getting to be more common. There are cars on the market with sealed transmissions and no dipstick. Gotta make that planned obsolescence to sell more units/get more repair jobs.
GotGrip?
Conversation Ruiner
Minnesota
Coming from a the auto repair side of this, manufactures 100% make the parts the way they do to sell more parts. The way things are put together/designed from body panels to mechanical is just terrible. The bodyshops best money maker for any vehicle is belt moldings, they range from $30 - 1000+ and there is no way to get them off without breaking at least 1 of their ****** 1/32 inch clip arms. Manufactured often don't sell the small pieces to replace to make them work either, you have to buy the whole part.
Eric Morris
IMO- if you can't afford a new PTU, you can't afford a SHO.
A plain jane SEL would get you to work just fine and the PTU would never fail on you.
Fordnatic
Alaska
Really?? That wouldn’t make a bit of difference. From what I’m reading the PTU Is failing in every platform that uses them-explorers, escapes, Lincoln’s etc. SHO has nothing to do with it. Just a ridiculously inept and inadequate design, which is what upsets me. If it had been abused in any way that would be different.
Jeff2017
I probably need to get my car into the dealer for the PTU fluid change. I have 27 miles on it. Probably let them do the transmission and radiator fluid at the same time.
ShogunofHarlem
Missouri
Well, I was gonna post that I miss my twin turbo beast until reading your post. I still miss the power but I don't miss the PTU issues and Ford's lack of care. If Ford really cared they would warranty the ptu for life or maybe 200,000 miles. Aside from ptu and fuel injector issues, I loved my SHO.
hosbaldosho
