flywheel.
mike25
92 sho
south carolina
When i have the flywheel resurfaced does the machine shop have to take off the dowel pins or do they leave them in.
K-Dawg
Treasure Coast, FL
I'm sure they will if you ask them to do it, but you can do it yourself. Round peg goes in the round hole.
93rev2sev
Hockeytown
I got mine back with the dowels taped to the back of the flywheel, which suited me just fine. I was able to clean up the dowell holes and add a smidge of anti-sieze so they'd come out easily next time.
frosho
WOLFMAN
Tyngsboro, MA
Whatever you do, make sure they don't cut the dowels flush with the friction surface. I have a big rusty paperweight in the basement thanks to some ******* machine shop.
AREA 91
PA SHO SHOP
Area 91
The dowel pins must be removed in order to cut the flywheel.
They should re-install them for you.
And im going to use valvoline atf should i get the maxlife or just valvoline atf.
It really depends on what your tranny likes. I hope you took the trans apart and replaced the edoff roll pins. How many miles on it? Any notchy, or grinding when shifting? Do any of the seals leak?
If the tranny shifts well, and does not leak, I would use regular ATF.
mike25
92 sho
south carolina
ok great, i was driving it home a week ago and i pushed the clutch in and it started make a light squeal untill i took my foot off the pedle, now when i start it put it in first clutch pedle all the way too the floor it will creep up alittle bit. and it makes alot of noise with the clutch pedle to the floor.
mike25
92 sho
south carolina
Havent done anything to it yet its still in my garage parked. Im waiting on some parts to come in then ill start.does the tob cause it to make noise when the clutch pedle is to the floor the noise goes away when u let the pedle out.and it will creep up when i start it i havent drove it since.
TYSHO
Earth
If you have a vise, you can remove them yourself to prevent the machine shop from whacking them off.
itwonder
VA
Any machine shop that does flywheels will have a special tool that pulls the dowel pins. Just tell the machinist you want him to pull and reinstall them for you; should not be a problem. Measure the dowel pin height and the pocket in the pressure plate to make sure they are not so tall that the pressure plate does not seat fully. Grind the pins off a bit if needed.
