mike25
92 sho
When i have the flywheel resurfaced does the machine shop have to take off the dowel pins or do they leave them in.
And im going to use valvoline atf should i get the maxlife or just valvoline atf.
Whatever you do, make sure they don't cut the dowels flush with the friction surface. I have a big rusty paperweight in the basement thanks to some ******* machine shop.
it has 130,000 miles on it shifts great dosent grind in any gears. and none of the seals leak.
do you need one fro?
