flywheel bolt thread
tardboy21
Woodbridge, NJ
I've got an engine pulled and did not loosen the crank bolt before hand. There is no flywheel on the engine and I don't have the bolts somewhere I can get to them. I need to find out the thread of the bolts so I can screw two in, and hold the crank steady to loosen the crank bolt. I tried a couple bolts I had lying around but none fit, seems like it may be something like M10x1. It is a pretty fine thread.
Anyone have some flywheel bolts lying around they can guage?
SHODWN
Mother Threasa
Spencer,Ma usa
Your correct about the size and pitch.. Off the top of my head I think they are 42mm long. I can check, but I know that fastenal has or can get them.
tardboy21
Woodbridge, NJ
Awesome, couldn't find them at Lowe's, they only go down to the 1.25 for M10 bolts and I knew that was too coarse. Got a fastenal right down the street, looks like I'll have to stop in today or tomorrow.
venom
Rowboat Design
Toledo, OH
M10 X 1.0 sounds right...
I know they are the same as the Gen I/II cars if that helps... I used Gen I SHO flywheel bolts to hold the Flywheel onto my V8 as the stock bolts for the flexplate were not long enough for the Mazda flywheel.
