Fluid changes
Aeterna
Austin
im going to try and change the fluids/oils in my 13 PP this weekend. I know i have seen a thread on this somewhere but i cant seem to find it.
Basically im wanting to change the fluids for the tranny, PTU, and Diff. And trying to see if anyone has tips/recomendation. Or if anyone knows of a good writeup that i cant seem to find.
Ideally, you would have the SHO on a lift, but if you can have all 4 corners on jackstands, that works well too.
Trans is pretty straightforward, you will need 15 quarts of fluid to do a 3 time drain & fill, simulating what a flush achieves. 5 quarts or so comes out each time.
Here's a writeup on doing the PTU fluid on a 13+ PP:
http://www.ecoboostperformanceforum.com/index.php/topic,4951.0.html
The RDU (rear diff) is more straightforward:
http://www.ecoboostperformanceforum.com/index.php/topic,1708.0.html
Popular aftermarket brands include Amsoil, Royal Purple, etc. Motorcraft is fine, as long as you don't test out the "performance" part of the SHO :nut:
Aeterna
Austin
Thanks, ive got access to a lift so it will be easy. Thanks for the info man. Does the maual say what weight gear oil to put in the tranny? I was planning on RP since i can get that locally and i hear their gear oil is very good.
The manual does specify all that info. The PTU uses 75w140, and the RDU uses 80w90.
  • 2013 Taurus SHO Maintenance Specifications.pdf
