Flow chart (or: solving the "what do upgrade first" question)
Devin
3.Slow
Pacific Northwest
I'm working on a flowchart for upgrades to the Gen 1/2 so that people can have a nice visual aid. With that in mind, ironically, I need to get a consensus on what the typical upgrade path is for NA and FI cars. I know the basics like maintenance first, exhaust, brakes, then power adders, but that is where it breaks for me.
Also, availability of upgrades should be noted too.
sperold
Last to Know
I think you have the order correct in your initial post.
Most people don't make it to the power adders, but the ones that do, go for turbo / supercharging as there is not much more you can do besides that.
Devin
3.Slow
Pacific Northwest
So where do things like Y-Pipes, various porting activities, butterflies (which I guess is a form of porting), catbacks, and cams fit? What buildup things are needed prior to FI?
SHOCH
Tommy Boy
near SHOcago
IMHO Brakes always come first, then suspension, then Y pipe, then Trunk Monkey, then the motor stuff.
sperold
Last to Know
The induction system is very good on these cars, so the equal length Y-pipe from ShoSource is a very good place to start. A true dual cat-back system is a great addition but the only manufacturer to offer it (Borla) does not make it anymore.
Because the induction system is inherently good, it takes a lot of time / money to make it better. The extrusion honing, big bore butterflies and cams all help, but for about the same money (if you have farmed it out), you can buy a supercharger set-up that you can install yourself and get better results, even with a low boost. Then a whole new frontier opens up where huge horse-power gains can be achieved (either by turbo or supercharger).
intimdatr
Got Cams?
Jefferson City, Missouri
Maintenance, Y-pipe, Brakes (11.6 and/or 13), Susp (whether it is a update or Upgrade), UDP (for the safety of your alt. Mine didnt like 6k), Gen 3 Subframe, BBBs and PnP, **boosted people go boost at this point, N/A continue** Cams (Tune at this point can help), High Comp Pistons, Tune (again). At that point you should be pretty much the top of N/A power in the SHO world without going the boosted route or power adders.
Honestly though, Y-Pipe, BBBs & PnP, UDP and the NOS after of course maintenance. Cheaper, easier, and faster.
