Hi there... I picked up a clean 95 ATX last week. The only problem is the car has no breaks.
At first pedal went straight to floor and car barely stopped. Bled at all four corners and couldnt get any fluid out of rear bleeders. Turns out both rear calipers are shot so i replace them, pads and rotors. Bolt everything up and tried to bleed again but couldnt get fluid in back, even tried with the lines discponnected from the caliper. However, the pedal is now firm.
Two former SHO owners work at my parts store and they have been helpful.. I was thinking master cylinder but they told me that they crossfed. They are leaning towards the brake junction block on the drivers rear control arm. Its a part they cant get and im assuming ABS related. Anybody got any other ideas ? I could raid junk yard for that part but its probably not much better shape....
The other funny thing is I had to grind an 1/8 in off each new brake pad to get clearance for the rotors to free spin....
