slowpoke17
With all the bad New England weather this past month I was finally able to take the SHO for a little drive since I bought it. Overall drove well, has incredible heat thankfully as it was around 25 degrees out. There is a clunking noise from the front end whenever I hit a bump or sewer cap etc. Sounds like something is loose like a shock. I also noticed that when I turned or gradually following a bend the wheel wanted to pulse in the opposite direction. Could that be the steering pump? Almost feels like something is slipping maybe? When idling the car has a slight hiccup every 5 or so seconds. Could they be connected with a serpentine belt issue?
