First Ecoboost to hit 600HP!
EcoPowerParts
AZ
The motor is STOCK internals.
The car has the following mods:
Dual in tank fuel pumps
6 auxiliary injectors
Split-Sec aux injector controller
Car runs on straight E85 - 23 degrees of timing.
PPE Engineering 2.5" catted downpipes with stock cat-back and sound performance racing cutout.
Custom turbo to intercooler and intercooler to throttle body piping with silicone tubes to replace factory plastic/rubber parts. Replaced factory electric BoV with Tial BoV.
First night
First pull 505HP/515TQ 15PSI - using stock ECU for boost control
Second pull 563HP/598TQ 23PSI - removed connection to factory boost controller, turbos running on wastegate spring
Next night
Third pull 587HP/642TQ 25PSI - same as second pull - allowed the boost activated cutout to open
Fourth pull 592HP/630TQ 25PSI - same as third pull - disconnected piping to filter in the fender
Fifth pull - not on video 600HP/642TQ - Cutout open, car had sat as we were uploading files to ECU - car was running cold air intake
We haven't tuned the car yet, this is a tune from Torrie at Unleashed from months ago on my old compressor wheel upgraded turbos with E85. We're just adding fuel via aux controller.
typhoon5000
Ferd Enganear
Shelby, MI
That's wheel HP! Holy mother! :eek: That's like 750 crank hp!!
Is your drivetrain all stock too?
[YOUTUBE]eIMsgZgeb4M[/YOUTUBE]
No mods to drivetrain that I have seen. Has been a challenge to control timing of the power transfer between front and rear wheels. Would like to go RWD at launch, basically, but PTU design may limit that to 50/50.
StreetlightSHO
It'll run eventually...
Phoenix-ish AZ
Hot damn! That's just insane. :hail:
Wasn't sure you were gonna pull it off when you mentioned a few numbers at the Pavillions a few months back....
totallytuned
WASHINGTON
Split-Sec aux injector controller ?
Is there anyway u can just upgrade the injectors to a high cc i/o adding more injectors??4DRHTRD
EcoPowerParts
AZ
No, not possible right now and even with a new HPFP and injectors they won't support the power levels where I'm going :)
Next mod water to air intercooler, then some ported/polished heads and forged block. :)
EcoPowerParts
AZ
Forged block = forged rods and pistons which CP Carrillo are ready for me with a set sitting in their shop.
Factory block = aluminum so I guess it could be considered forged....
:p
