silverknight
i race taurus?
So.... i decided after reading all the turbo posts on here, i have a few questions.
car has had 60/120k, full maint, rebuilt trans w/shift kit, extra trans cooler, so all that is maintained. just want a bit more power.
what i am looking for is like 6psi or so. target of 250 wheel or a lil more. have a 155lph fuel pump, 80mm maf, will either be going superchip with a local tuner on a dyno, or tweecer. many superchip tuners locally know do turbo fords.
also for turbo of this low of boost and hp.. i can get an audi a4 k03 turbo with no shaft play for a low price locally, but will that be too small? i'm still slightly confused on reading the turbo mapping.
it is mainly a roadcourse car, but also summer cruiser like 1300 on street, and 2000 on highway. but i dont want to **** the trans, so building boost at higher rpms would almost be better, but still not too much power. like i want power mainly at 3000rpm to 7200rpm. or do i not need to worry about trans issues at speed in 2nd and 3rd gears as much at launch, which i dont do much?
also, with f/i, what kind of plugs do i go with, do i go a few degrees cooler in an NGK? currently running oe spec motorcraft.
