93SHO_2
I bought the Felpro ES 70425 water pump gasket set which came with 3 "O" fings, 2 with thicker rubber than the third all about the same inside opening diameter.
1.) Does this gasket set work with both 3.0 and 3.2?
2.) The box says there is one 94829 Water Supply Tube "O" Ring, my box had 2 of this thicker (more ruibber) "O" rings. Is it usual (or required) to replace the "O" ring at the thermostat end of the supply tube?
3.) The box says there is (and there was only one)one 94900, I assume this is the thinner (less rubber) ring that goes between shrug the pump housing and the engine block. Correct?
