fan stayed running
Moneypit
Houston Texas
i turned the car off and went inside and came back out 30 min later and the fan was still running, i put the key in and it turned off. Anyone know why? :shrug:
I would say the relay in the CCRM stuck. If it happens again give it a wack.
morpho18
Des Moines, Iowa
I have the opposite problem. My fan has not been kicking on when needed, and hence my car has been running really hot lately. It is also losing coolant from somewhere, however, i can find no leaks. This all started after I took my intake off for cleaning. I reconnected all of the coolant lines, and triple checked them before i started my car. the coolant lines by the throttle body are not leaking, the upper and lower radiator hoses arent leaking, so I'm beginning to think that maybe a head gasket has gone bad?? I dunno. I just need to figure out why the fan stopped running.
It doesn't run at all? There are two speeds for the fan and two relays in the CCRM to control this. I would first apply 12v directly to the fan to see if it works. Then go backwards to the CCRM or the ECT sensor.
morpho18
Des Moines, Iowa
What does CCRM stand for? I have a new ECT to put in, but I just couldn't get the old one out when i tried. Where is the ground for the cooling fans at? It may have been disconnected.
Dava Ralph
Bismarck ND
I had that problem I got a new battery and Sears hooked it up and my fan wouldnt turn off at all. The next day I go outside knowing my car wouldnt start. So i took it to a dealership and they said the battery was hooked up wron and blew out my CCRM. IT cosT me $200. Stupid Sears ******** :headbang:
